Old 18-Mar-2012, 4:19 PM   #4
dumpingCable
Your TVFR looks very good. Depending on the materials used in your home's construction, an indoor antenna could work very well.
http://forum.tvfool.com/showthread.php?t=2828
Thanks for the reply...my 50" Plasma is 10' from a large front picture window > however the front window faces west-wrong direction. Brick construction front/rear side walls are attached to other houses (row/town homes) flat rubber roof over second floor. Back dining room window faces east.
I would prefer an indoor antenna, but if the reception is questionable I'll mount something outside on my deck railing and 'can' point it directly at 18-20 degrees to the right of true north. However it would only be 20' off the ground.
dumpingCable is offline   Reply With Quote
