Old 5-Mar-2012, 2:34 AM   #1
Poormountaineer
Troubleshooting signal
In an effort to provide as much info as possible, this will likely be a long post.
My current set up is rooftop antenna (picture below) 30 ft off ground, connected via a short 300 ohm wire to my preamp which is a Philips SWS2083W/17 Outdoor 28dB Antenna Amplifier (bought and installed in 2009). From there I am using RG6 to go into the house where it goes into a splitter and the power supply for the preamp. From the splitter it goes to two TV's, one using a RCA converter box and one using a built in tuner (Zenith Z50PV220 TV).
As a side note, I had to move the antenna to the roof because my house has steel siding on it.
The Zenith tv was recently purchased to replace another TV that died that had a built in tuner . We hadn't had any issues with reception until recently. The issue is intermittent and is obviously caused by weather at times, but even so the TV using the converter box seems to have less issues, although we only turn that one on when the new tv is having issues to compare picture.
Stations (real, not virtual) I have received and would like to receive:
35, 22, 20, 45, 43, 38, 32, 12 (this was quite reliable, but neither tv receives it currently) Any other stations from the northwest would also be welcome. I linked my tvfool report below.
What I have tried:
Disconnecting the preamp - lose all signal, at least no stations can be tuned.
Removed splitter
Used converter box to check signal strength at both TV locations with and without splitter installed, signal strength at both TV locations is within 1% of each other.
I checked all connections to make sure they are tight.
Check cable for damage, and removed some slightly damaged cable.
Tried slowly rotating the antenna, only to move it back to original position.
I took the back cover off my preamp power source it smelled of hot electronics, but as I said above without it, I get no signal so it must be working at least a little.
1. Does anyone know if the converter boxes typically have better tuners than the ones built into TV's? Are they able to handle more noise than built in tuners? It seems like ours outperforms both of the tvs we have had with built in tuners.
2. My antenna is old and came with the house when I purchased the house 7 years ago, any idea what gain I could expect to be getting from it? I realize it is not ideal and could use replacing, so suggestions on that would be appreciated. I am currently considering a DB8 or a channel master 3671 (although I am somewhat concerned about it being directional since I don't have a rotor.)
3. I realize I bought a cheapo preamp 3 years ago, I was experimenting and didn't want to spend to much, so is what I am experiencing my preamp possibly going bad and sending more than its fair share of noise down the line? Is there a way to check its performance with a multimeter?
4. I know this is a distinct possibility, does it sound like I have a bad tuner in my new tv? Or is this what I would experience when I have too much amplification of my tv signal?
5. Do cell phone towers cause any major interference? My antenna is currently pointed about 3 degrees away from one and I can easily see it when standing on my roof next to the antenna.
6. If I were to get a rotor and a CM 3671, any idea if I might pull in any of the stations from the northeast (I would love to get 16 so I could have another option for football in the fall, I have picked this channel up in the past, but mainly because of atmospheric conditions)
I think those are my only questions, so please let me know if you need more detail.
http://download.p4c.philips.com/file...17_dfu_aen.pdf
http://www.tvfool.com/?option=com_wr...0b86d0616efbed
Poormountaineer is offline   Reply With Quote
