Old 1-Jan-2012, 9:44 PM   #2
If you're limited to using an indoor antenna, you'll have a tough time seeing all of the major US networks. Still, it's worth trying. Reception of the local signals should be much easier.
Consider the Terk HDTVi. http://forum.tvfool.com/showthread.php?t=2828
(If I had the option to roof mount, a Winegard HD7698P aimed at Burlington, VT would not be overkill IMO. Reliable reception of the US networks will require that you overcome adjacent and co-channel interference, which is usually the job for a high gain directional antenna. That would still leave you needing a rotator or second antenna for reception of the local signals.)
