Old 4-Nov-2011, 6:01 PM   #41
Billiam
Originally Posted by marni13 View Post
I still can't get ION. I'm not nearly as happy with this Antenna Craft as I was with the original antenna I had. I'm going to get a rotor and raise the antenna some more to see if this helps. If not, I'll look into getting a preamp. Alot of our channels are pixelated, which is very frustrating. We didn't have nearly as much trouble with the original antenna, which I returned!
Which Antennacraft model are you using presently?
You will likely need a preamp in this situation. But, yes first try some additional height to see if that solves the problem.
Old 4-Nov-2011, 10:49 PM   #42
marni13
Antennacraft HBU-33
marni13 is offline   Reply With Quote
Old 5-Nov-2011, 1:42 AM   #43
Billiam
The location may also be the problem. I had to try three different locations on my roof before I could find the best spot that gave me good reception of all my local signals. HDTV signals are pretty finicky.
Old 5-Nov-2011, 2:41 PM   #44
marni13
Unfortunately, the roof is not an option. I am the one messing around with this stuff for the most part. So we have the antenna on a 3/4 inch conduit pipe running up the side of the shed. So far, we have it at approx. 10 ft. I know this is part of the issue, but I can't climb around on the roof! This is what I have "bookmarked" to buy when I get the money:
1. WINEGARD HDP-269
Low Noise, High Input UHF/VHF Pre-Amp!
2. Round 3 Wire Rotor Cable
3. Model TDP-2 Antennacraft Heavy-Duty Antenna Rotator
Old 5-Nov-2011, 2:44 PM   #45
Billiam
Good rotor. I own one and like it. It will easily handle much larger antennas if needed. I have an HBU 55 on it and it works great.
The pre amp you've chosen is usually the one people recommend for stronger signal areas. So, this should work especially if you get the antenna up a little higher. At ten feet you have too many obstacles in the way of the signal to the antenna.
Old 5-Nov-2011, 2:58 PM   #46
Did you ever try connecting the antenna directly to 1 TV with no splits? This is a good place to start before adding any amplification.
