Old 27-Feb-2012, 7:28 AM   #21
ant
OK, we are going to try it ourselves without professional installers and with smaller to see if they get anything. Would http://www.costco.com/Browse/Product...rodid=11646220 be a good choice to start from Costco?
If not, then what specific ones to get that are returnable from local retail stores to see, buy, and be able to return easily if these don't work.
Also, where can I find professional antennae installers for La Habra Heights, CA 90631?
ant is offline   Reply With Quote
Old 27-Feb-2012, 3:52 PM   #22
MisterMe
OK. There are three obvious problems here. The first is that Costco is charging $10 over Winegard's price for the FV-HD30. The second is that you have chosen an antenna that is better for line-of-sight locations whereas you have a mountain between the transmission towers and your home. You have chosen a J-mount mast which will probably limit your antenna height to 15-20 feet whereas you need to mount your antenna as high as you can get it.
The FV-HD30 is a good antenna, but it is not a good antenna for you.
Old 27-Feb-2012, 4:26 PM   #23
As a test , Yes put the antenna up and see what can be received.
Old 27-Feb-2012, 4:54 PM   #24
The FCC web site shows that KVMD is transmitting. http://transition.fcc.gov/fcc-bin/tv...=0&facid=16729
Old 27-Feb-2012, 6:20 PM   #25
Yes, they have filed a license to cover their primary site that covers the city of license, Twentynine Palms. If you scroll further down that page, you'll see all the pending applications for the multiple locations for their proposed distributed transmission system that would have covered much of the Los Angeles metro area.
There is already a channel 23 licensed to Mt Wilson and another STA for La Habra Heights (KSGA-LD) which re-broadcasts KVMD. KSGA-LD has applied to move to UHF-30.
Given the overlapping and contradictory information in the FCC's database, I don't know what to believe might actually be on the air in the OP's neighborhood. Someone local to the area would need to provide first-person details.
Old 27-Feb-2012, 6:45 PM   #26
ant
Question
All I know there were about nine subchannels (foreigns including Chinese). What else to check for with a portal TV with basic antennae?
Old 27-Feb-2012, 6:48 PM   #27
ant
OK unless there is another antenna I can get. It will be on one of the weekends...
Old 27-Feb-2012, 7:30 PM   #28
MisterMe
KVMD RF-23 broadcasts ten sub channels--all at 480i--using Virtual Channel 31. Its programming consists of sub channels dedicated to PBS and various foreign languages including Chinese and Armenian.
Old 27-Feb-2012, 7:33 PM   #29
ant
Yeah, that sounds about right.
Old 27-Feb-2012, 7:39 PM   #30
ant
Question
Where exactly is this STA in La Habra Heights? http://www.kvmdtv.com/code/coverage_m.html doesn't show it. That explains why I pick this 31.x so easily compared to others. I wonder if it is the same antenna tower I saw near by. I noticed this tower in the short NE distance: http://static.panoramio.com/photos/o...l/33774086.jpg ... http://www.antennasearch.com/sitesta...number=1013567 says a radio transmitter for a small college? Maybe this is not it? I wished I could stick my antenna up there.
Old 27-Feb-2012, 8:09 PM   #31
See this page: http://transition.fcc.gov/fcc-bin/tvq?list=0&facid=5342 It has the coordinates for the transmitter site. The second photo matches the satellite overhead.
I had a conversation with Ken Brown the Chief Engineer , KVMD. I am composing the results of the conversation , I will return.
Excellent. That should answer questions and clear confusion.
Old 27-Feb-2012, 8:22 PM   #32
ant
Thumbs up
See this page: http://transition.fcc.gov/fcc-bin/tvq?list=0&facid=5342 It has the coordinates for the transmitter site. The second photo matches the satellite overhead...
Ah hah! That's it! It is about a half of a mile in NE then. Heh, let's bring the rest of the stations over to this area. [grin] It was interesting that http://www.antennasearch.com/sitesta...number=1013567 does not say much about it as a TV translator.
Old 27-Feb-2012, 10:26 PM   #33
KSMV , KVMD , KIMG , KSGA , are 4 Tv transmitters that will cover most of costal / mountain areas of southern Ca. When all 4 are transmitting. Towers and transmission equipment is in place and has been tested , Waiting for the FCC approval. Currently KSMV at Mount Wilson is the only one that is transmitting on UHF23. Even so , my recommendation for tv reception still stands. The Tv stations/channels to the south east are , CBS , Me-TV , ABC , The Cool Tv , Azteca America , FOX , Antenna Tv , This Tv , Independent channel , NBC , PBS , XHDTV.
Old 27-Feb-2012, 10:41 PM   #34
The Tv stations/channels to the north west that can received are , ABC , The Live Well Network , FOX , Independent Channel , MyNetwork , Bounce Tv , Retro Tv Network , AMG Tv , America One , Tr3's , Telemundo , NBC , CW , Antenna Tv , This Tv , TBN.
Old 27-Feb-2012, 10:49 PM   #35
Of all the Main digital channels and digital sub channels to the north west and south east , I only see one CBS channel and that is to the south east , KFMB digital channel 8 CBS with digital sub channel Me-Tv.
Old 27-Feb-2012, 10:52 PM   #36
If you will like to install one antenna to begin with , I recommend a HD7084P antenna. You can aim it to the north west or south east.
Old 27-Feb-2012, 10:54 PM   #37
Old 28-Feb-2012, 3:48 AM   #38
ant
Question
I'd wouldn't be too concerned about height, but I would be about directivity of the antenna and it's location.
I'd go with a two antenna combo, one for VHF and one for UHF. The UHF would be a 91XG. I'd mount it on the roof in a location where you can exeriment on the height to maximize the signal on your weakest UHF station. Next I'd get a Y10-7-13 for VHF. I'd use a 7777 preramp to combine the antennas.
Do local retail stores carry these types and similiar indoor house antennae to use like in the attic that is returnable easily like at Best Buy, Fry's Electronics, Costco, etc.?
Old 28-Feb-2012, 3:48 AM   #39
ant
4-5 probably. All CRT currently though. We will get HDTVs later on. For now, let's concentrate on getting the local broadcast channels.
Old 28-Feb-2012, 3:50 AM   #40
ant
Question
Cool, they have this in my local Fry's Electronics store (returnable), but not Best Buy. Do I assume this one can be used indoor like in the attic too?
