Old 1-Aug-2011, 7:37 PM   #21
Old Stuff
Thanks to "No static at all"
Delighted to take you up on your offer for the Winegard 7082. Will send a private message with contact info so I can arrange pickup.
Many thanks!
Old Stuff is offline   Reply With Quote
Old 2-Aug-2011, 1:33 AM   #22
dcp12345678 has his or her Own question asking site , yet came here. This is a answer to the question that dcp12345678 ask here on , Old Stuffs question asking site . The question does not have any thing to do with the Old Stuff question. Not all antennas by a manufacture are the best at every thing. Antennas by different manufactures can be good for some reception situations and some not. The Antennacraft U4000 will receive in 2 directions , the same type and kind of winegard antenna will not.
Old 2-Aug-2011, 2:02 AM   #23
dcp12345678
That makes sense, thanks for the clarification.
dcp12345678 is offline   Reply With Quote
Old 5-Aug-2011, 9:44 PM   #24
Old Stuff
Back in Business
A HUGE thank you to "No static at all!" I picked up a Winegard HDP-269 pre-amp for a good price at Buy.com, got some new RG-6u cable, and today installed the Winegard 7082. I set the antenna at 55 degrees and was immediately able to get all the channels I was interested in. I had the strongest signal I have ever received on Channel 50/CW. Channel 22/MPT signal was only at 37 percent, but that was without moving the antenna. So I am a happy camper!
Old 7-Aug-2011, 12:45 AM   #25
Glad to hear it is working well. Just curious if you seeing anything from Baltimore? WBAL- 11 was the only channel I really had much success with the 7082 in that area.
Also, make sure the system is well grounded. The HDP-269 is sensitive to static build-up & nearby lightning strikes.
Old 8-Aug-2011, 12:29 AM   #26
Old Stuff
Baltimore
Channel 11 is the only Baltimore station I can get, even though 2, 13, 45 and 54 have the same azimuth and are the same distance away. I get about 35-40 signal strength on Channel 11, with intermittent pixelization.
I have groundwires on the antenna mast and on the coax just before it goes into the house.
