Old 17-Jun-2020, 1:53 PM   #21
rickbb
At that length I'm sure he guy wired it down.
I've always worried a high wind would bend EMT around too much if the mast had any height to it.
Old 17-Jun-2020, 4:43 PM   #22
Tim
Yes, attached to the house with a bracket about half way up and guyed about 5 feet from the top. Very stable.
Old 20-Jun-2020, 7:46 AM   #23
Pistachio
Oh, and do keep us informed about the G450 rotator. If it pans out for you I will order two myself. My fear is that it is some sort of Chinese clone. When it arrives you should probably call the company and see if that's a valid serial number...
Your intuition seems to have been correct. The G450 is being shipped from China. I will wait to see what arrived before I decide on an action. What do you think? I am curious if the rotator that arrives is a cheap or well made duplicate, I doubt it will be authentic.
Pistachio is offline   Reply With Quote
Old 20-Jun-2020, 4:37 PM   #24
Tim
It will be interesting to see what you get. I have received some Chinese knockoffs of products that are just as good as the original and others that were severely lacking in worksmanship and quality control.
Old 20-Jun-2020, 4:54 PM   #25
I use EMT for masts all the time for TV and ham radio use. Just be aware that the outside diameter is larger than the trade size designator of the EMT.
EMT works fine for very short masts. For longer masts top rail is preferred. This is because the steel used in EMT has a yield strength of 30,000 PSI. The steel in top rail is rated at 50,000 PSI.
Note that pipe is also rated at 30,000 PSI, but is available in wall thicknesses that can make up some of the weakness of lower strength steel.
Old 23-Jun-2020, 8:46 PM   #26
bobsgarage
Antenna Enthusiast
bobsgarage's Avatar
Sleeving 1 3/8" top rail internally
I have experimented with 21 foot 1 3/8" SS-20 top rail and sleeved it internally with 10 foot sections of 1" water pipe, the fit is perfect. I laid out the two water pipes , put a 12 mm deep well socket in between the two and welded the two water pipes together and shoved them inside the top rail for a sturdy 21 foot mast.
Rotor killer though.
Old 30-Jun-2020, 12:09 PM   #27
bobsgarage
Antenna Enthusiast
bobsgarage's Avatar
YAESU 450 is it what it is or is it not?
ANY WORD?
Seriously! I need one! Or two...
Old 30-Jun-2020, 3:49 PM   #28
Pistachio
Homeworx HW130STB initial review
Apparently, you can scan or set the channels yourself in advance. This way you dont have to scan and re-scan all the time.
Yes, there is a add Channel function. So even if you're not receiving the channel at that time you can still program it in and when you Rotator is rotated correctly you will receive that Channel.
I have been using the Homeworx HW130STB for a few days now and it is good for the most part. Picture quality is great, it changes channels quickly, there is a guide to tell you what is on all the channels for the next couple hours. On individual channels it tells you what is on now and next.
The annoying thing is that when you change to a channel the guide showing you what channel and what is playing currently does not disappear for 5+ seconds. It takes up a good part of the screen so you can't see what is happening. You can hit the info button twice to get rid of it faster but that is not a good solution when you are clicking around. I haven't messed with it too much so maybe there is a way to adjust or turn that function off.
The other pitfall with the Homeworx HW130STB is that it uses an IR optical remote control. You have to point the remote directly to the unit and when I am about 20' away it does not always receive my clicks so I end up having to either keep clicking or walk closer to the unit.
Overall for $30 it is great, they should just put in a radio (not IR optical ) remote! And fix that window that pops up and stays on when channel surfing.
Old 30-Jun-2020, 4:01 PM   #29
Pistachio
ANY WORD?
So I was not familiar with Yaesu prior to this thread mentioning it. That said, I did not really consider that I might receive a Chinese clone and not the original. Yaesu is a Japanese company and it does seem that they do have some factories in China for certain products after searching the internet a little bit (but I am not sure about this). That said, the device is not here yet but it looks like it will show up today after 18 days from putting in my order. Maybe Yaesu has a factory near CHENGDU, CHINA. I will keep you posted on what they have sent me once I get it.
June 12, 2020 Ordered online
June 17, 2020, 5:17 pm
Acceptance
CHINA
June 17, 2020, 8:15 pm
Processed Through Facility
CHENGDU, CHINA
June 24, 2020, 1:55 pm
ISC SAN FRANCISCO (USPS)
June 28, 2020, 8:18 pm
Arrived at USPS Regional Facility
SAN FRANCISCO CA DISTRIBUTION CENTER
June 30, 2020, 7:10 am
Out for Delivery
SAN DIEGO, CA
Old 1-Jul-2020, 3:09 AM   #30
bobsgarage
Antenna Enthusiast
bobsgarage's Avatar
A while back on AVS we talked about the Homeworx Vs. the Channelmaster and how they used the same software.
Don't know if its worth reading for you:
https://www.avsforum.com/forum/186-c...erter-box.html
Old 1-Jul-2020, 3:11 AM   #31
bobsgarage
Antenna Enthusiast
bobsgarage's Avatar
Acceptance
CHINA
CHENGDU, CHINA
Out for Delivery
SAN DIEGO, CA
I hope, I hope, I hope, it's not a scam! Please let us know how it goes, I'll buy 2 or 4 or ….
Old 1-Jul-2020, 6:48 AM   #32
Pistachio
Wrong item shipped. I contacted the vendor and my credit card company. Both are responsive but I too hope it was not a scam. I think I am covered so either I end up with my cash back or the actual item. I will keep you posted.
Old 12-Jul-2020, 5:28 PM   #33
bobsgarage
Antenna Enthusiast
bobsgarage's Avatar
What Happened?
Did you get the rotator or some BS?
Old 12-Jul-2020, 7:50 PM   #34
Tim
He had to wait 18 days for the first order so I imagine he is still waiting on the correct replacement. Will be interesting to see if he gets it and if it is genuine. If so, I will be tempted to order one.
Old 13-Jul-2020, 5:17 PM   #35
Pistachio
So where I am located all both VHF-Hi and UHF channels are at either 10deg or 140deg so I thought I needed a rotator. Also, I thought I would need both UHF and VHF antennas. So far, I hooked up a UHF 8-bay bowtie antenna (ANT7285 https://www.homedepot.com/p/Digiwave...ord=W958886826) and pointed it at 140deg. I am getting all the channels that come from 10deg and even the VHF ones that I did not expect to receive at all. So that said, I don't think I need a rotator or dedicated VHF antenna. Thoughts?
I requested them to cancel the order, but there is some confusion there so I am not sure if they are still going to ship it out or refund me. I cannot tell if they are illegitimate or just disorganized. I am leaning towards the latter. If it does show up I wont be heartbroken since the cost is nice but I don't think its necessary for my system.
This is not yet resolved so once I receive either a refund or a rotator I will let you know.
Old 15-Jul-2020, 2:29 PM   #36
Tim
Well, if you end up getting the rotator and it is a genuine item (or even a well made copy) I'm sure you won't have any problem passing it along to a new home and recoup your costs.
