Old 25-Jul-2014, 2:44 PM   #21
As a Test to Prove Reception.
Trees and Tree Leaves , Absorb and Block Tv Reception , And so do roofs and buildings.
Locate the DB8e antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions directions of reception.
If required , Install the antenna higher to avoid obstructions.
Here is how to aim antennas ,
Aim both panels at about 350 degree magnetic compass direction.
Have only the DB8e connected. And Not the add on VHF antenna kit.
Use NEW Coax to make all connections outside and NEW Coax run through a open door or window in to the house , direct to 1 Tv.
For a preamp use a ,
http://www.antennacraft.net.
10G201 preamp.
Digital Tv Tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
As a Test.
Can also aim the DB8e at WEAU at 281 degree magnetic compass direction and scan for channels to see if WEAU will be received.
Last edited by teleview; 28-Jul-2014 at 9:21 AM. Reason: Clarify information and typos.
