Go Back   TV Fool > Special Forums > TV Fool Discussion / Database Updates
Old 12-Jan-2018, 3:38 AM   #1
Sev
Question Whats up with the TV Signal Analysis?
Something happen to the data base?
Notice the lack of the channels to the north east @ 60 - 63 degrees. And the difference in channels at 255 - 263 degrees.
This is my original chart from over a year ago.
This is one form tonight.
Sev is offline   Reply With Quote
Old 12-Jan-2018, 12:28 PM   #2
Sev
It would be nice if one of the site admins would chime in with an explanation.
I cant be the only individual getting flaky data.
Also the View Map function on the Callsign Lookup, View Map function appears to not be working.
I tried several browser and shut off all the security addons with no effect.
I went to Find TV signals.
Interestingly is showed the WKPT transmitter. Even though it is not on my TV Signal Analysis Results
The Transmitter Profile appears to work.
Old 12-Jan-2018, 1:38 PM   #3
Not a word has been heard from Admin.
You are not the only one; many reports are wrong because of the current defective database, date code 201711011344. You can get the details here on this thread:
***Alert*** New database has serious issue ***
http://forum.tvfool.com/showthread.php?t=16376
Old 12-Jan-2018, 2:13 PM   #4
Sev
Thanks Rabbit. Much appreciated.
How have you been?
Old 12-Jan-2018, 3:30 PM   #5
Hello, Sev
I'm OK for an old man of 85. I still love to make antenna measurements.
Here is a report for your location from rabbitears.info:
and this one is from the FCC DTV maps site. I added the dBm values:
Old 12-Jan-2018, 4:20 PM   #6
Sev
Hello, Sev
LOL.
It keeps you young.
Thanks for the reports. I generally get better reception than is reported. I just happen to be located in the right spot.
I am still playing around with antenna setups.
The other day I received a HD8200U by accident. Really wanted the HD7698P to stack with the my Archer VHF antenna.
But hey. For 60.00 bucks it was a good deal.
Not quiet sure yet if it has been an improvement over my radioshack VU-190xr
I really need to get a shop set up so I can build my own.
Old 12-Jan-2018, 4:46 PM   #7
LOL.
It keeps you young.
Yes, it does.
All I have ever had was the kitchen counter and a temporary table on the porch.
Yes, a good deal. It should make WCYB on VHF-Low channel 5 very strong.
Old 12-Jan-2018, 5:06 PM   #8
Sev
Yes, it does.
I'll have to do some tests.
I believe everything came in stronger according to its meter.
Except for Channel 68.1 Not an important channel in any case.
I also recently bought a Silicondust unit. One of the most recent models.
HDHR5. So far it has proven itself not to have a tuner the equal of my avermedia stick or the one in the TV.
A bit disappointing.
I am wondering though if it could be a faulty unit.
Old 12-Jan-2018, 8:43 PM   #9
That unit is probably not faulty, but the design is faulty. The problem is with the internal splitter which makes the system noise figure worse. This raises the noise floor that reduces the SNR of the weakest signals. IOW, it isn't as sensitive for weak signals.
The original HDHR with two tuners had a separate antenna input for each tuner:
That was the best way to design a dual tuner HDHR; it is still needed now with multiple antenna systems:
https://www.highdefforum.com/local-h...-rf-input.html
The present dual and quad tuners use an internal 2-way or 4-way splitter. There is an internal amp to make up for the signal loss in splitting, but the damage to the System Noise Figure still exists and can not be undone.
Some users have more than one HDHR connected to a network for a multiple antenna system to avoid the internal splitting.
Old 12-Jan-2018, 9:52 PM   #10
Sev
Hmmmm.
Missed a few good deals on those in the past. Luckily I got this unit on Cyber Monday.
Looks like a couple later models have 2 tuners and 2 inputs as well.
Back to ebay to do a comparison with.
Old 12-Jan-2018, 9:55 PM   #11
Have you read this thread?
http://forum.tvfool.com/showthread.php?t=820
Old 12-Jan-2018, 10:10 PM   #12
Sev
Nope.
I will though.
Old 12-Jan-2018, 10:21 PM   #13
Sev
I wonder how the tuner is going to be in the new Channel master that is coming out?
https://www.channelmaster.com/Stream...tail_TechSpecs
Old 13-Jan-2018, 1:16 PM   #14
Sev
I found a couple of them cheap on ebay.
Might have to pick one up for testing purposes.
I recall reading somewhere a while back that there were still updates from silicondust for it.
