Go Back   TV Fool > Special Forums > TV Fool Discussion / Database Updates
Old 28-Aug-2014, 8:31 PM   #1
kweiner
Database Correction
These three stations:
WRIC
WRLH
WCVW
were operating at low power due to a transmit antenna issue. These three stations are back at full power, but from the TV Fool results it looks like the calculations are based on the temporary low power.
WRIC for example: TV Fool shows the ERP at 60 kW, while the FCC shows them at 850 kW. Please refer to http://transition.fcc.gov/fcc-bin/tv...=0&facid=74416 for additional details.
The other two stations are in the same boat.
Here are the parameters I used when I noticed this:
Select input method: Coordinates
Latitude: 37.513581
Longitude: -76.979436
Antenna height (ft AGL): 115
Thanks,
Kevin Weiner
kweiner is offline   Reply With Quote
Tags
database correction
