Old 17-Sep-2013, 3:07 PM   #1
HankNJ
Antenna pick for Philly and New York
Need to choose an antenna , single or two . would like to pick up the New York I can get the Philly stations , doing it on rabbit ears. this is my info http://www.tvfool.com/?option=com_wr...46aee3239ef3fa . The antenna will be installed on roof with 3 ft. stand on 3 ft. pole . If two antennas are needed how far apart should they be ?
HankNJ is offline   Reply With Quote
Old 17-Sep-2013, 4:11 PM   #2
HankNJ
Cool Reception Philly and New York
Can pick up Philly on rabbit ears , but is it possible to get New York ? http://www.tvfool.com/?option=com_wr...46aee3239ef3fa . On roof install and multiple TV's inside. What antenna or stacked , amp ?
Old 17-Sep-2013, 11:39 PM   #3
HankNJ
Cool Antenna pick for Philly and New York
Would like to possible receive channels from both NY and Philly. here`s the info http://www.tvfool.com/?option=com_wr...46aee3239ef3fa . There is 3 TV's in house , furthest is 75 ft. away. Roof mount tri pod 5 ft. pole.
Old 20-Sep-2013, 12:17 AM   #4
To receive the Philly area Tv stations and receive as many of the New York Tv stations as possible using 1 antenna aimed in 1 direction.
Install a Winegard HD7084P antenna above the roof aimed at about 43 degree magnetic compass direction.
Use a Old School magnetic compass to aim antenna.
______________
Install a Winegard , LNA-200 'Boost' XT amplifier.
______________
For 2 or more Tv's connected , the LNA-200 , power supply , power injector , preamp must all be before the input of the splitter , or , use a splitter that passes power through the splitter so the power supply and power injector can be on the inside of house.
Here are some power passing splitters.
Holland Electronics , HFS-2D , 2 way splitter.
Holland Electronics , HFS-3D , 3 way splitter.
Buy the HFS splitters at , http://www.solidsignal.com.
http://www.amazon.com.
_________________
Old 20-Sep-2013, 4:58 PM   #5
HankNJ
What about using Denny`s HD stacker , or is it subpar ? And if I`m pointing at 43 deg`s will the antenna will pick up philly also?
Old 20-Sep-2013, 5:39 PM   #6
stvcmty
Teleview is suggesting to aim a high gain antenna at NY, and get the close and strong Philly stations off the back/side of the antenna. WPVI is a vhf low station, so it needs a big antenna, hence the recommendation for the HD7084P. Ignoring anything else about the stacker, it would not get you a good signal in the VHF low band.
