Old 22-Apr-2013, 1:36 AM   #1
ladyh
Antenna directions
The attached picture is my roof antenna.... does the V shape the way it is now point to the transmitters or do I turn it around and the stem part points to the transmitters?
Thanks
ladyh is offline   Reply With Quote
Old 22-Apr-2013, 8:15 AM   #2
It looks as if the reflectors (V shape) are mounted backward or the boom (stem) is.
Here is an example similar to your antenna, a UHF Yagi type antenna with corner reflector: http://www.winegarddirect.com/viewit...P%29&p=HD9075P
In the drawing, the back of the antenna is on the left, attached to a mast. The end closest to the transmitter is on the right side of the drawing.
Old 22-Apr-2013, 1:54 PM   #3
ladyh
Thank you... I was getting a lot of channels but some were pixelated and no signal etc... I know nothing about antenna... you solved my problem... THANK YOU>>
