Old 28-Feb-2013, 8:41 PM   #1
darkmatter
Will this work?
My report is on going to antenna. I am wondering if I can do this to help with reception. I have my Winegard hd7084p pointed at 162 degree magnetic. If I install a clearstream 2 uhf antenna lower on the same mast at 32 degrees and combine them with a winegard cc-7870 to a single coaxial into my house. I already have 2 seperate coaxial cables coming into my house 1 for fm 1 for tv both to a tripplite surge protector. I have no more coaxial connections on the surge protector. I've tried turning the winegard antenna but I then loose another station that i like to watch.
darkmatter is offline   Reply With Quote
Old 28-Feb-2013, 9:01 PM   #2
If it works, it's the least expensive option
Chances aren't good, but it wouldn't hurt anything to try. There are more reliable ways to make use of multiple antennas... http://forum.tvfool.com/showthread.php?t=2882
Old 1-Mar-2013, 2:16 PM   #3
darkmatter
Ok thanks for the quick response and help. I will look into the sugestions and try to decide what I can do.
