Go Back   TV Fool > Special Forums > TV Fool Discussion / Database Updates > TV Database Updates
Old 3-Aug-2010, 6:03 PM   #1
PeterMorris
errors in TV Signal Analysis Results
WKOI-TV (virt 43.1) broadcasts from Richmond, Indiana, which is approximately 34 mi. (certainly not 9.3 mi.) from Hamilton, Ohio. For
this reason, the estimated signal Pwr. (-52.5 dbM) must be in error.
WKEF is virt 22.1. (not stated).
Sincerely,
Peter R. Morris
PeterMorris is offline   Reply With Quote
Old 29-Aug-2010, 12:32 AM   #2
mtownsend
Thanks for the update!
As ADTech responded already, it does look like WKOI is broadcasting from a tower very close to Hamilton. If you are close to this transmitter, then yes, the signal strengths will be quite strong.
The virtual channel number for WKEF has been fixed.
FYI, these changes should take effect immediately on any newly generated reports.
