Old 10-Apr-2012, 3:24 PM   #1
z3geo
Need help choosing Antenna
Here is my Report http://www.tvfool.com/?option=com_wr...361649dbc6d220.I will be mounting the antenna on roof using 30-40 ft of coax hooked to existing cable which is hooked to 4 TVs Would like to get reception of some red if possible.Am cutting gable and would like as stable reception as possible.All TV, are DTV no conversion boxes.Appreciate your advice George
z3geo is offline   Reply With Quote
Old 10-Apr-2012, 4:36 PM   #2
Consider the Winegard HD7696P or HD7698P. You may need a distribution amplifier, but the strong signal from WZRA could be a problem.
Try the CM3414 amp or HDP-269 preamp and a passive splitter.
Old 10-Apr-2012, 4:57 PM   #3
Tv antennas and Tv reception
For reception of the , Green , yellow and red. Install a Winegard HD7698P antenna aimed at about 171 degree magnetic compass. here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Install a Channel Master CM3414 , four output distribution amplifier.
Old 11-Apr-2012, 12:22 AM   #4
coco
I see that you live along the gulf coast in Florida, I live along the gulf coast in Louisiana. The winegard 7698P antenna is over 14 feet long.Do you think you would have place to store that monsterious antenna if a hurricane is coming your way?
This is my tvfool report:
http://www.tvfool.com/?option=com_wr...3616f2751aa185
I get reliable 24/7 reception all the way down the list to WLPB-TV channel 25
This is the antenna I have had for the last 2 years with NO PROBLEMS :
http://www.dennysantennaservice.com/...v_antenna.html
coco is offline   Reply With Quote
