Old 25-May-2021, 5:59 PM   #1
BrooklinOTA
Help with antenna selection
Hi Everyone,
Everyone has been so helpful over the years, I thought I might return here for a bit of advice.
We had a big wind storm a few weeks ago and my DB8e fell off the roof. I have found a way to secure the antenna pole better now but I'm wondering if there is an antenna out there that is a bit small with a similar reception ability.
Here is my RabbitEars report: https://www.rabbitears.info/searchma...tudy_id=267511
What worked well about the DB8e is I would point it to the US stations in Buffalo and it would reliably get those stations. I would also get the stations from the CN tower really well even though the antenna would be pointed away from that source.
Any advice or should I just go back to the DB8e and try to secure it better?
BrooklinOTA is offline   Reply With Quote
Old 26-May-2021, 5:21 PM   #2
I’d consider a DB-4e. The Buffalo stations are spaced apart so that a 4 bay would cover for them as well as the narrow pattern on a DB-8e. In addition, you might need a small VHF antenna for the one Toronto VHF station.
Old 26-May-2021, 5:47 PM   #3
BrooklinOTA
Thanks! Do you think that the DB-4e is a better choice than the Clearstream C4?
Old 27-May-2021, 7:02 PM   #4
Yes, I do. The DB-4e has a wide horizontal pattern and a narrow vertical pattern. The C-4 has a narrow horizontal pattern and a wide vertical pattern. The wide horizontal pattern allows for stronger signals for off-axis reception of some of the Buffalo stations.
Old 27-May-2021, 7:05 PM   #5
BrooklinOTA
Excellent. Many thanks for your time.
