Old 26-Jan-2016, 3:54 PM   #1
markf
Long range help
Looking for advice on selecting an antenna. We live between Orlando and Jacksonville, both between 50-60 Miles away. Only really need to get the three networks. Is it possible?
http://www.tvfool.com/?option=com_wr...5134570a729a79
Thanks in Advance for the help.
Mark
markf is offline   Reply With Quote
Old 26-Jan-2016, 5:43 PM   #2
Tower Guy
I'd aim a Winegard HD 7698P at Orlando. Mount it on the roof. You'll also need a preamp.
Old 26-Jan-2016, 6:52 PM   #3
WESH operates a UHF-18 translator in Deltona. That can make the VHF-capable combo unnecessary. A UHF 8-Bay with suitable preamp should work fine.
Old 26-Jan-2016, 7:33 PM   #4
markf
Can you recommend an 8-Bay and preamp?
Old 26-Jan-2016, 9:13 PM   #5
Tower Guy
You're right. I missed that.
Old 26-Jan-2016, 10:49 PM   #6
Antennas Direct DB8e.
and preamp?
Channel Master 7778
FM signal report
http://www.fmfool.com/modeling/tmp/c...8/Radar-FM.png
ABC might be marginal; it's a lot weaker.
http://www.tvfool.com/?option=com_wr...ALLTV%26n%3d19
If it is too unreliable, try also weak WJXX real channel 10 with a VHF-High yagi aimed 345 degrees magnetic and combined with the DB8e with a UVSJ.
http://www.mcmelectronics.com/produc...-2476-/30-2476
Old 26-Jan-2016, 11:38 PM   #7
markf
How would The ClearStreamâ„¢ 4 compare to a Antennas Direct DB8e?
The ClearStream is smaller and may not upset the neighbors as much!
Old 27-Jan-2016, 12:48 AM   #8
The C4 has less gain than the DB8e and would make WFTV ABC 39 even more unreliable, but you are welcome to try it.
https://www.antennasdirect.com/cmss_...-sellsheet.pdf
The DB8e, with both panels aimed in the same direction, is the current champion when it comes to UHF gain.
https://www.antennasdirect.com/cmss_files/attachmentlibrary/Technical%20Data%20PDF's/DB8E-TDS.pdf
Would the 91XG be acceptable?
https://www.antennasdirect.com/cmss_files/attachmentlibrary/Technical%20Data%20PDF's/91XG-TDS.pdf
The tvfool reports for 2Edge signals are less accurate, so it is difficult to predict results with the accuracy you would like. With so many factors involved it isn't possible to make a guarantee.
You must expect some experimentation will be necessary. It might boil down to making a choice between reliable reception and appearance.
