Go Back   TV Fool > Special Forums > FM Fool Discussion/Database Updates > FM Database Updates
Old 1-Oct-2010, 3:12 PM   #1
dtvengineer
WRCJ correction
WRCJ-FM transmits 42kW
dtvengineer is offline   Reply With Quote
Old 1-Oct-2010, 5:59 PM   #2
mtownsend
Thanks for the note!
It looks like our database already has WRCJ at 42 kW. Do you see it listed otherwise somewhere?
Old 1-Oct-2010, 6:24 PM   #3
dtvengineer
When I do a signal locater search, it shows up as 4.94kW in the table. Is that a different database?
Old 1-Oct-2010, 6:41 PM   #4
mtownsend
Ahh. That power level is the effective radiated power based on the directional antenna information filed with the FCC. The 42 kW represents the max ERP of the transmitter setup, but some directions will get less than that.
Here is the FCC's service contour map for WRJC:
The power levels shown in the signal reports have already been adjusted for radiation pattern depending on the location entered by the user.
Sorry for the confusion.
Old 1-Oct-2010, 6:48 PM   #5
dtvengineer
OK, that makes sense. Thanks for the clarification.
