Old 4-Oct-2013, 9:03 PM   #1
1badmf
New House/New Antenna
Hello Everyone-
You were all very helpful last at the last house with a great antenna recommendation. I'm at a new house and could use some help.
I'm looking to get the green channels clearly, and put the antenna in the attic.
Thanks for your help.
Here's the channel listing:
http://www.tvfool.com/?option=com_wr...46ae75c50dbe44
1badmf is offline   Reply With Quote
Old 4-Oct-2013, 10:33 PM   #2
It sounds as if your previous location (http://forum.tvfool.com/showthread.php?t=9384) came together well using an attic mount.
If the new attic turns out to have similar characteristics, you can use the same antenna as before, the RCA ANT-751R. If you have difficulty from inside the attic, test reception outdoors.
