If you could consider mounting outside, clear of obstructions, a smaller antenna would be appropriate. In the attic, you need a larger antenna to overcome attenuation caused by roofing and the underlying construction materials.
To preemptively answer a common question in situations like yours, signal not received by the antenna can not be created by an amplifier. So no, using a small, low gain antenna with a high gain amplifier is not a technically sound option.
Chimney mounted panel antennas such as the CS-4, DB-4, U4000, HD4400 CM4221 are rather unobtrusive. They are not very good at receiving real channels 7-13 and quite poor on channels 2-6. A high VHF antenna will be smaller than the HBU-55 which would make it easier to fit in the attic. The outdoor UHF and attic VHF are easily combined with an inexpensive UVSJ (UHF / VHF Signal Joiner). I'm thinking Antennas Direct CS-4 facing NYC, try it alone... if you get satisfactory reception, great. If you're missing one or more real channels in the range of 7 through 13, add a Winegard YA-1713 pointed toward NYC and a UVSJ.
