Old 9-Nov-2017, 6:47 PM   #1
lobo012847
WOFL 35 not showing on your grid map
As you requested. Channel 35 WOFL in Orlando is not showing on the grid map listing channels in the Orlando area.
lobo012847 is offline   Reply With Quote
Old 10-Nov-2017, 11:44 AM   #2
READ THE INDICATED THREAD: See http://forum.tvfool.com/showthread.php?t=16376
Old 10-Nov-2017, 12:29 PM   #3
lobo012847
Not registering
I am not registering. I am simply informing you that you do not show a channel -- as requested on this site.
Thank you
Old 10-Nov-2017, 1:43 PM   #4
And I'm telling you that the reason is in the thread I keep telling you to read.
Old 10-Nov-2017, 3:10 PM   #5
Thank you for the report. The TVFool website has been informed of channels missing from many reports. They do not have enough staff to make corrections. The new database that was entered at the beginning of Nov that is used to generate the reports is defective.
We understand that you are not registering. You would not be able to post if you were not registered.
Here is an extract from a TVFool report that does not show WOFL:
http://www.tvfool.com/?option=com_wr...60ed25a15f7ff1
Here is a report from the FCC DTV Reception map site that does show WOFL:
I suggest you use the FCC site to double check a TVFool report:
https://www.fcc.gov/media/engineering/dtvmaps
The reason why you were instructed to check the other thread is because it gives the explanation and an example as above.
