Old 13-Nov-2015, 5:27 PM   #1
generalfirst
generalfirst
I have been trying to get information on direction my antennas should be aimed. I do not have a meter to check on strength of signal. I have just installed an Antennas direct Db8E and an Antenna Craft Y5713 on the gable end of my house. My zip code is 17408. I have been using a compass but obviously it is not as accurate as a meter. Can you tell me which direction for each antenna and degrees?
Thank you
bfoltz@consultingpluspa.com
generalfirst is offline   Reply With Quote
Old 13-Nov-2015, 6:14 PM   #2
I found your old link to a radar report. Your VHF antenna should be aimed at 341 to pick up WHTM. Your DB-8e needs to be split in two directions; 351 and 64 degrees.
