Old 27-Mar-2013, 4:21 AM   #1
Ihave3days
Crazy TvFool results...
I have been building free DB4's for friends that do not have the fiscal means to pay for Cable TV for a couple years now. (I would cut the Cable TV cord myself, if the wife would let me haha).
I am building my 6th DB4 antenna, but this time it's for my Pops.
Since he is one of those "impossible to shop for" people, I thought a handmade DB4 would be the perfect gift for him, so he could still watch TV in case of a storm/emergency.
I started putting the antenna together tonight, & pulled his TVfool location... & that's where I got a little overwhelmed...
http://www.tvfool.com/?option=com_wr...1dda8328e8ddfc
I have NEVER seen such a crazy TVfool schematic, & to be honest, I don't even know where to start...
I have always had a set of towers in 1 direction that required a reflector screen, but these results make me think I should forgo the reflector, for omnidirectional capability.
So my questions are:
1. Would you use a reflector in this case?
2. What (Magnetic North) Degree would I even try to start pointing the thing?
Ihave3days is offline   Reply With Quote
Old 27-Mar-2013, 5:49 AM   #2
Having Tv stations in Multipul directions is the most common reception situation.
Having Tv stations in one direction is less common.
_____________________________________________
The home built and manufactured bow tie type antennas are a UHF channels 14 thru 51 antenna design. That will receive to a lesser degree VHF high band channels 7 thru 13.
And not much at all of channels , 2 thru 6.
The current Broadcast Tv Channels are.
UHF band channels 14 thru 51.
The tvfool location has , Many , Strong Signal Strength , UHF channels and VHF high band channels.
The home built bow tie antenna should work OK.
Aim either side of the home built bow tie antenna , With Out the reflector screen at about 200 degree magnetic compass direction.
Old 27-Mar-2013, 12:16 PM   #3
Nothing "crazy" about it - your location is between two major markets - DC and BMI. This is a very common situation, especially in the Northeast.
A bi-directional UHF/VHF antenna will likely work fine. A reflectorless 4-bay antenna with an additional VHF dipole will likely work fine. Orient it so it is perpendicular to an imaginary line that connects the DC and BMI broadcast towers.
