Old 30-Jan-2013, 11:17 AM   #1
sofakng
Can I put an antenna in the basement? (3 mile distance from towers)
Here is my TV Fool link: http://www.tvfool.com/?option=com_wr...1dda15919747a1
I'm only 3 miles from my local HDTV towers, so I'm wondering if it would be possible to put an antenna in my basement (which is 80% underground).
If so, does anybody have an antenna suggestion for me? Something small and highly directional I'm guessing?
EDIT: What if I mount a small antenna below the floor joists (in the basement) which is just above ground level (so it's not underground). Might that work?
Thanks!
sofakng is offline   Reply With Quote
Old 30-Jan-2013, 2:29 PM   #2
The --> Only Way <-- to find out.
Is install a Terk HDTVi (not HDTVa) antenna aimed at about 60 degree magnetic compass direction.
Here is how to aim indoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Old 30-Jan-2013, 4:20 PM   #3
middleofnowhere
it probably won't work. You are only 3 mi from transmitters but the ground will block ALL transmissions. putting it in the joists may work, but with such heavy construction in floors i don't guarentee anything.
Not to mention all sorts of random distortion and diffraction everytime someone walks by upstairs.
Assuming that you only want the big-name transmitters from your 3 mi towers a small directional antenna (upstairs a set-top would be more than enough) sounds like the best bet to me. You can always mount it higher in your house (if possible). You'll need one with UHF/high-VHF capabilities, if you want NBC and CBS.
P.S don't buy too big of an antenna, you're pretty close to your transmitter(s) and you could overload something with a huge antenna.
middleofnowhere is offline   Reply With Quote
Old 30-Jan-2013, 5:10 PM   #4
No static at all
No static at all's Avatar
Over a mile away, overload is very unlikely. At 3 miles, nearly impossible even with a large antenna, unless of course some type of amplification is used.
Old 30-Jan-2013, 7:25 PM   #5
sofakng
I have a Winegard HD7082P at my old house that I still need to move into my new house...
I'm hesitant about putting it up in the attic (because it's a crawl space) but I might just do it and get it over with. However, it does seem like overkill for these local channels, doesn't it?
Should I just buy a Mohu Leaf or something and put that in the attic instead? (I'll still need to drill/run wire into the basement, but what can you do...)
Old 30-Jan-2013, 9:24 PM   #6
If you already own an HD7082P, try it. It's more antenna than I would spec. in this application but it won't break anything. It would certainly provide enough signal power to drive an 8-way splitter if you had the need.
Old 31-Jan-2013, 2:02 AM   #7
Install the HD7082P antenna above the roof , with no preamplifier , aimed at about 40 degree magnetic compass direction , and also receive .
WSWB-DT REAL UHF Digital channel 31 , virtual number (38.1-2) The CW and Me-Tv.
WQPX-DT REAL UHF Digital channel 32 , virtual number (64.1-2-3) ION and Qubo and ION Life.
http://www.ronard.com/909911.html if using a tripod antenna mount use a 5 foot antenna mount.
http://www.ronard.com/34424560.html if using a eave antenna mount use the #4560.
http://www.ronard.com.
Buy the ronard antenna mounts at http://www.solidsignal.com by typing the word ronard in the solidsignal search box or buy from ronard.
