Old 24-Oct-2013, 1:08 PM   #1
DonVK
Channel listing - Ottawa (Kanata), Canada
This is some FYI info for Kanata, Ontario, Canada, K2M1Y9. The TVfool's channel listing and radar map differ from what my TV reports.
I used the radar map for aiming an attic mounted Digiwave ANT-7287 antennae (4 bays North, 4 bays EastSE 110deg ). My TV reports the following channels (listed first), which differ from the radar map (listed second).
4.1 CBOT-DT [radarmap : missing ]
6.1 CIII-HD [radarmap : OK ]
6.2 CIII-SD [radarmap : missing ]
9.1 CBOFT-D [radarmap : labelled as 33.1 ]
11.1 CHCH-HD [radarmap : missing ]
13.1 CJOH [radarmap : OK ]
14.1 ONMI2 [radarmap : missing, weak signal]
24.1 TVO [radarmap : labelled as CICO ]
30.1 CIVO-DT [radarmap : OK ]
34.1 CFGS-HD [radarmap : OK ]
40.1 CHOT-HD [radarmap : OK ]
60.1 OMNI [radarmap : missing, weak signal ]
65.1 CITYTV [radarmap : labelled as 17.1 ]
DonVK is offline   Reply With Quote
Old 20-Jan-2014, 6:10 PM   #2
tvlurker
The Industry Canada database upon which TVFool bases its Canadian entries does not track virtual channel numbers, thus CBOFT-DT is listed as 33.1
Some of your stations may be missing if you do not click on 'pending'.
tvlurker is offline   Reply With Quote
Tags
kanata, listing, ottawa
