Old 31-Oct-2012, 10:41 PM   #5
Is the antenna the CM4228HD?? or the older CM4228??
Aim the CM4228 antenna at about 170 degree magnetic compass direction.
This will put the front of the antenna in between 152 degree magnetic compass direction and 187 degree magnetic compass direction the 2 groups of Tv stations to the south east and south.
And put CKVR-DT channel 10 , CTV TWO , at less of a steep angle to the back of the CM4228 , hopefully this will provide enough reception of CKVR-DT 10 through the back of the antenna to be received reliably.
____________________________
There have been some changes of channels that are being transmitted.
Compare the Current Digital channels list and the Pending Applications Included Digital channels list.
Digital Tv tuners can develop , Digital Glitches , and a simple channel rescan will not clear out the glitches.
Do a double rescan.
Disconnect the antenna coax from the tv and channel scan for Digital Broadcast Tv channels , this will clear out the tuner for a fresh new channel rescan.
Unplug the Tv from electric power , wait 1 or more minutes and then plug the Tv in.
Now connect the antenna coax to the Tv and channel scan for Digital Broadcast Tv channels.
http://www.dtv.gov/rescan.html.
_______________________________________
Also , ALL outside coax is suspect of being bad , even though it looks good that does not mean the coax is good.
One situation but not the only situation is , Water can get into the coax , if water gets into the coax then discard the coax.
Connections and connectors can be bad , loose connections , corroded connections.
And ALL other coax and connectors and connections and hardware are suspect of being bad.
As a Test of reception , run a New Coax from the antenna Direct to the Tv through a open door or window , no couplers , no splitters , no nothing , it is , antenna -> coax -> Tv.
All so I recommend installing a Channel Master CM7778 preamp after all the checking and testing is done.
http://www.channelmasterstore.com , http://www.saveandreplay.com , http://www.trentondistributors.com.
