Old 7-Aug-2015, 9:49 PM   #11
musicman
my mistake
Rabbit73:
For some reason I did not scroll down far enough to read the second part of your answer. I'm sorry I missed it.
I redid my TVFool report using my exact address. It is in a rural area and not close to any city. There are tall trees all around my cottage. Here are the results :
http://www.tvfool.com/?option=com_wr...8e03254f5a6a88
You are correct I did mean CIII-DT and CHCH-DT.
I have replaced most of the 300 OHM twin lead with RG6 coax but will replace all as you suggested.
I'll check out where to buy a grounding block and attach it as you suggested.
Thanks again for you help and patience.
musicman is offline   Reply With Quote
