Old 14-Jun-2020, 5:08 PM   #10
Pistachio
Thanks for the additional information. I am not familiar with the Homeworx HW130STB tuner that you plan to use. I wonder if you have to rescan the channels each time you change antenna directions?
A less expensive alternative to the rotator would be to install a second UHF antenna for the stations you want to receive from Mexico and have a coax A/B switch to switch between your two UHF antennas.
Wow, that really is a super price on the Yaesu rotator. In fact, almost sounds too good to be true. Have you ever purchased from the writland.com website before?
So I know I am in special situation where most of the channels are coming from a couple directions. Mutiple Fixed antennas vs. rotator?
I was still thinking of going with a rotator to fine tune the channels (plus I actually already bought the one I mentioned before I saw this post, lets see it actually shows up). For day-to-day use maybe the multiple fixed antenna solution is better since I don't have to wait for the antenna to move around?
Thoughts?
Pistachio is offline   Reply With Quote
