Old 9-Nov-2014, 3:19 PM   #2
Stereocraig
Originally Posted by 223fan View Post
http://www.tvfool.com/?option=com_wr...5b94141d8be2a8
This is my current setup
2-HDB91X
1-91XG
CM7777 preamp
I currently get channels 8(abc),18(abc),39(ion). I can receive channel 46(NBC) only when it's below freezing. The colder it gets the better I receive it. I understand less heat less signal distortion, but why only below freezing ?
For the same reason we can hear farther under water.
Tighter molecules, along w/ less heat distortion, as you mentioned.
You can verify this, by driving past businesses that have burglar alarms/ door openers and a radar detector. In warm weather, you need to be right on top of them to activate the detector and in colder weather, you can be considerably farther away.
Properly running cars, also run better in cold weather.
