Thread: getting started
Old 4-Dec-2012, 11:33 PM   #2
For reception of ,
CFTO-TV Analog Channel 21 CTV ONE.
CIII-DT Digital channel 7 GTN Global.
CHCH-DT Digital channel 23 IND.
CKVR-DT Digital channel 10 CTV TWO.
Install on the tower , a Winegard HD7696P antenna aimed at about 220 degree magnetic compass direction.
No preamplifier is required.
For 1 Tv connection use no splitter.
___________________________________________
Here are places to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.amazon.ca , http://www.solidsignal.com , http://www.winegarddirect.com.
______________________________________________
The Tv should be a Tv that receives both the Digital Broadcast Tv Channels and Analog Broadcast Tv Channels.
Replace All of the Antenna and inside wiring with New RG-6 coax wiring.
__________
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
At your location that is , west and south.
