Old 24-Jan-2014, 6:16 PM   #3
Install a , www.antennacraft.net , HBU33 , Above The Peak Of The Roof aimed at about 19 degree magnetic compass direction.
Here is how to aim antennas , www.kyes.com/antenna/pointing/pointing.html
A antenna system amplifier is not required.
For 3 Tv's connected use a simple common 3 way splitter.
For 4 Tv's connected use a simple common 4 way splitter.
www.ronard.com/909911.html
www.ronard.com/34424560.html
www.ronrad.com/ychim.html
Measure around the chimney and Use a , ronard(2212) , ronard(2218) , ronard(2224) .
Last edited by teleview; 25-Jan-2014 at 2:18 AM. Reason: Clarify information and typos.
