Old 27-Aug-2014, 5:34 PM   #3
-->MANY<-- Digital Broadcast Tv Stations/Channels Will Be Received.
The Main Group of Digital Broadcast Tv Stations/Channels are to the , West , West North West.
Above the Peak of the Roof in such a manner that reception is not , obstructed , impeded , blocked , by the , attic , roof , building.
Install a.
http://www.antennacraft.net.
HBU44 antenna.
Install a.
10G201 preamplifier.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
http://www.hollandelectronics.com , or , http://www.amazon.com.
Aim the HBU44 antenna at about 280 degree magnetic compass direction.
Here is how to aim antennas.
Use a Real and Actual magnetic compass to aim antenna , do not trust a , cell phone , tablet and etc. compass.
To assist the best reception , Most Digital Tv's have a Signal Strength Meter and some Digital Tv's also have a Signal Quality Meter.
As always , antenna aim and location can be adjusted for best reception.
Here are some Above the Peak of the Roof antenna mounts.
http://www.ronard.com/909911.html. Install the , ronard(911) , 5 foot tripod antenna mount.
http://www.ronard.com/712.html. Install the , ronard(712-50-10) , 10 foot tripod antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney and install a , ronard(2212) , ronard(2218) , ronard(2224) .
http://www.ronard.com.
Home Depot has , 10 foot 6 inch lengths - 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE , that makes excellent antenna mast/pipe.
The price is low at about 12 dollars.
If installing a tripod antenna mount , Do Not bolt the tripod antenna mount in place until a good reception location is found.
Avoid aiming the antenna in to trees and other obstructions in the directions of reception.
Antenna height is one and not the only way to avoid aiming the antenna in to trees and other obstructions.
Another way is to locate the antenna where trees and other obstructions are further away from the antenna in the directions of reception.
__________________________________________
Antenna Web is conservative to the point of being defective.
The owner of antenna web Knows it is Defective and does nothing to fix it.
This is the way much of the Internet is , the money continues to flow in from the sponsors and no needed change happens.
The sponsors do not care.
It is not about the correct information , it is about ego and money.
Last edited by teleview; 28-Aug-2014 at 4:02 PM. Reason: Clarify information and typos.
