Old 28-Aug-2014, 7:33 PM   #6
stvcmty
Originally Posted by KevinTMC View Post
Thanks for the helpful replies. These antennas look a bit bigger than I was expecting...I'll have to double-check the neighborhood covenants to make sure I wouldn't be violating some rule by having one nice and high on the roof.
As long as you do not rent and you do not live in a historic structure, no one can keep you from putting up an antenna. (If a property is a rental, there could be limitations with regards to drilling holes in a structure).
For safety reasons, an antenna more than 12’ above your roof may be subject to local laws.
http://www.fcc.gov/guides/over-air-r...n-devices-rule
At the same time, there are conditions the neighborhood covenants could impose (preference for back/side of the house for example), but ultimately they cannot stop you from putting up an antenna to reliably receive signal.
stvcmty is offline   Reply With Quote
