Old 9-Mar-2015, 8:04 PM   #14
tomfoolery
Originally Posted by NapMan View Post
Is that particular brand and model your best recommendation or would another vertically stacked model work as well (such as the Channel Master CM-4221HD)?
I recommended it both as an example of the type (4-bay 'bowtie' in a vertical array), and because it's probably the best example of that type, since it's designed for channels 14-51 rather than 14-69 (52-69 are no longer used for tv), so the gain is likely to be slightly higher overall. And because I have that one and it works well for me, though that's hardly enough to make a buying decision on. And you can get support from the manufacturer, including here.
