The front of the DB8 the reception side of the antenna is the side that has the V shaped metal elements. The screen/reflector reflects signals to the V shaped metal receiving elements. If the antenna is turned around so the screen/reflector is facing the transmitters then not much will be received. If the coax cable in the walls is receiving Tv transmissions then that is not good. The coax needs to be grounded with a coax grounding block to electric service ground. If after grounding the coax with out a antenna connected is still receiving watchable tv signals then there is a problem with the coax. . How many Tv's will be connected????
