Old 25-Jul-2011, 3:07 PM   #10
So my thought is, since it is behind stucco, first of all, the amp on the antenna will likely help out with that.
Amplifying a signal that is received from behind a stucco wall is the wrong way to go about it. Move the antenna. Amplifying a crappy signal will give you an amplified crappy signal.
