Old 25-Jul-2011, 9:58 AM   #5
If you were to not have a rotor and point the HD7698P in one direction then point the antenna at 180 degree magnetic compass , South. However you will not receive , WXII-DT 31 NBC and WUNL-TV 32 PBS to the west and you will not receive the tv stations to the north. And Yes you still need to use RG-6 Quad Shield coax a coax ground block connected to electric service ground. And also use the FM Trap.
