Old 25-Jul-2011, 9:51 AM   #4
John Candle
Tv Antennas and Reception
No need to settle for less. I recommend a Winegard HD7694P antenna mounted on a Channel Master CM 9521A rotor. Due to the strong FM transmitter , I recommend use RG-6 Quad Shield Coax and a coax grounding block connected to the electric service ground. Also use a FM Trap. The radio shack 15-024 is a good FM Trap.
