Old 25-Jul-2011, 5:01 AM   #1
wpbacon
Need help near Omaha, NE
I'm just north west of Omaha, NE. I'm using a Antennas Direct DB8 Multidirectional HDTV Antenna, Winegard AP-8700 Preamplifier, and an 8-Port Bi-Directional Amplifier/Splitter Signal Booster for my HTPC. I have a two questions.
1.) I live close enough to Omaha, the local stations are picked up by the coax cable in the walls of my house even before I added the antenna. There are stations farther to the south and southwest I'd like to pick up. Can I direct my antenna toward the farther stations in the south and southwest without losing the nearer stations in Omaha to the east? Can you suggest a good direction to maximize my reception?
2.) When I first hooked up the antenna, I had it sitting in my living room and picked up about 15 stations. My young daughter wouldn't leave it alone, so until I could mount it on the roof I put it in the basement. Number of stations went down, as expected. Since I don't have the time to roof mount the antenna for a while I then moved it to my bedroom on our 2nd floor. There, it had to face north, away from most of the local and distant stations. But the number of stations I received went to 30. Then I moved it to my son's bedroom, also on the 2nd floor. His window faces directly south, toward more of the stations I want to get. The number of stations went to 14. Any idea why I would lose stations when I moved to my son's room?
I've attached the digital radar map for my area. Any help to improve my reception would be appreciated.
wpbacon is offline   Reply With Quote
