Thread: Reception Help
Old 24-Jul-2011, 9:08 AM   #4
Metal siding , metal backed insulation , metal roofs , concrete walls , brick from ground to roof , reduce and block tv transmissions. If the house is a standard wood frame house with wood or plastic siding then a NON AMPLIFIED indoor tv antenna will likley work. http://forum.tvfool.com/showthread.php?t=233 . The rods of the indoor antenna will be on a line with north and south.
