Here is a variable attenuator , Antennas Direct model 1296F . The transmissions at the top of the list are over the top strong. For a outdoor antenna I also recommend a ANT751. If using a outdoor antenna I strongly recommend grounding the coax with a coax ground block. If you put the antenna in the attic I still recommend ground the coax with a coax ground block. The coax ground block connected to a ground , directs interfering signals to ground , because the receive location will have interfering signals. I also recommend aim the ANT751 at about 290 degree magnetic compass.
