Tv Antennas and Reception
You can try a Channel Master CM4228HD with a CPA-19 preamp aimed at 360 degree magnetic compass or 0 degree magnetic compass , North. The CM4228HD is designed to have extended limited reception ability below the UHF channels to receive VHF High channels 7 thru 13. The size of the antenna is 3' 6" X 3' 1".
