Old 22-Jul-2011, 6:12 PM   #3
captain_tinker
Ah yes, was going to include this and forgot.
http://www.tvfool.com/?option=com_wr...03f3c58779a008
Just not sure if I would be able to put it anywhere outside easily. I think I will at least try it in the garage and see how it works, but I guess if it doesn't perform exactly how I want it, I'll open the garage and put it outside for a bit and see if it works better. If so, I'll just have to find a way to make it work. I'm really leaning towards the Winegard MS-2002, it sounds like it should work, and there are a lot of positive reviews on it. I guess check out the report, and see what it says to you. There are really only about 9 or 10 channels that I am looking to get anyway, 3.1, 6.1, 6.2, 10.1, 13.1, 29.1, 40.1, 40.2, 58.1. Any more than that would just be gravy, or icing on the cake, whichever idiom you prefer.
As for that terminator, I did not realize that signals could bounce/reflect like that. I thought that was mainly a SCSI issue. (Yeah, I'm an old computer geek) It is not likely that I will have any open ports, but if I do end up with any, that is certainly not a bad price for the terminator.
I was also thinking, that since I would need to distribute the signal to several tuners through the house, sometimes through some long cables (up to 50 ft tops) that a signal booster such as this would likely be needed?
http://www.frys.com/product/4478276?...H:MAIN_RSLT_PG
They have 1, 2, and 4 output models I've seen. I was thinking a 2 output would be what I needed.
captain_tinker is offline   Reply With Quote
