Originally Posted by GroundUrMast
If you are willing to wait for the folks at WGPX to act on their construction permit you may be able to save the expense of a second antenna. You may want to contact the station to get an idea of the ETA on that upgrade.
I actually found the local station number this time and believer it or not I actually talked to a human! She said she is going to have her engineer call me back and let me know the status, but she didn't know of any plans to update their tower. So I would assume it's probably not something that's going to happen soon, if at all. But I guess the more people that whine about it, the better.
The second option would be a two antenna system. The 4-bay design previously described plus the AD XG-91 aimed at WGPX. Combining the signal from both antennas may be possible with a custom built product from TinLee.com but I think an A/B switch would be more practical if you are on a limited budget.
Can you tell me a little about these signal combiners? Are there any you recommend? I really want to keep things simple with the TV, without having to deal with rotators, A/B switches, etc. In other words, I would probably just live without WGPX if it meant having to use an A/B switch or rotator.
In either case, the antennas need to be outside. You will also need an FM trap inline between the XG-91 and a high input preamp such as the Antennas Direct CPA-19 or Winegard HDP269. Finally, successful reception of WGPX at it's current power and antenna height may require a high mast or tower, due to the low signal strength and 2 edge path profile.
I live in a 2 story house. What kind of height are you thinking here? I think the FCC law only allows me to go 12 feet above the roofline (
http://transition.fcc.gov/mb/facts/otard.html). Is that your understanding?
If I decide to just give up on WGPX but do want to go with a higher powered antenna to get some of the farther away stations, like in Charlotte for example, would going with the XG-91 as a single antenna solution be the way to go, or would it be better to go with a 4 bay solution like the Wineguard or Clearstream4?
Also, on a slightly unrelated topic, do these antenna(e) need to be grounded? What's the best way to do that? Could I ground it somewhere in the attic (e.g it would be mounted on the the roof, and the cable would come into the attic where from there I would drop it down to my living room.
