Old 20-Jul-2011, 11:54 AM   #50
dcp12345678
Originally Posted by John Candle View Post
I did NOT recommend the clearstream four. I said the U4000. I recommend the U4000 because it will receive WXII-DT 31 and WUNL-TV 32 through the back side of the antenna.
Right, but in your follow up post (see first page of this thread) you mentioned this:
"If you will like to try and receive them any way then a separate antenna can be installed , I suggest a Clear Stream 4 antenna pointed at about 215 degree magnetic compass."
So that's what I was referring to. Of course, I think with the Clearstream4 you only intended for that to be used in a multi-antenna solution.
dcp12345678 is offline   Reply With Quote
