I will run a #8 ground wire from antenna mast to the ground wire that runs from service panel > through the wall> into the ground. And connect coax to same pre-existing ground wire with grounding block. Is this acceptable or must I dig up ground rod and connect directly to rod? and...can i run coax alongside of #8 ground wire from antenna to ground rod wire? I'm guessing there won't/shouldn't be any reception issues as the coax is shielded.
Thanks for your help.
