Old 19-Jul-2011, 8:52 PM   #46
dcp12345678
Given the predicted signal strength and path profile of WGPX, I would be less than 100% certain of a single fixed aim antenna solution. But I would try the 4-bay panel as JC has suggested.
By the one JC recommended, you mean the ClearsStream4 (http://www.amazon.com/Antennas-Direc...1104088&sr=8-1), right?
The reason I didn't think it would pick up WGPX was because Scott already said he couldn't pick WGPX up with his Winegard 9095P. So are you saying that you think the ClearStream4 has better potential of picking up this station than the Wineguard does?
I would probably just live without WGPX if I had to go with a rotator or multi-antenna solution, as I really want to keep things simple if I can.
dcp12345678 is offline   Reply With Quote
