Old 17-Jul-2011, 9:49 PM   #12
John Candle
Tv Antennas and Reception
The odd front to back ratio that Tower Guy is refering to at the other post of anubis93611 has with the same question is , zero front to back ratio. This likley to be a typo mistake. And even so in any event in this reception situation both antennas have little front to back ratio. If front to back ratio was what we are after here then a much larger antenna would be in order , a much larger antenna will not work because the larger the antenna is the more narrow the beam width is and that will not work with this reception situation. Tower Guy knows this.
