Old 17-Jul-2011, 8:07 PM   #4
mtownsend
Thanks for the update! The data should be fixed now.
It turns out that the IC database still shows CHNM-DT as an active transmitter with 830 Watts. The 8.3 kW transmitter has a callsign of CHNM-DT(2) and is listed as "AU" (which by default goes into the "pending" category on TV Fool).
So to fix things, we removed the CHNM-DT records (830 Watts) and migrated the CHNM-DT(2) record (8.3 kW) into the "current" category.
I believe this now reflects what you were expecting.
