Lots of viewing choices...
The Antennacraft HBU-22 would be my choice of the two you have listed.
If PBS is important to you, you'll need to split the aim point between 32° and 92°. There is plenty of signal power on most of the channels so I expect you will be able to find an aim point that gives reliable reception of all the major networks.
(If you want every possible channel, neither of the two antennas would be up to the task. Do you have a list of 'MUST have' stations, by call sign?)
